confused avatar image
confused asked ·
Why do I feel cold and shiver when I have a fever?
peoplehealth
10 |600 characters needed characters left characters exceeded
· Write an Answer
einstein avatar image
einstein answered ·
A fever is when your body increases its internal thermostat, found in the hypothalamus. If you exercise hard or it’s a hot day, your body temperature might increase, but the thermostat remains at around 36.8°C. When you feel hot the hypothalamus tries to correct this with sweating and increased blood flow to the skin. But with a fever, it is the thermostat that has risen. This means your body temperature is now below 36.8°C, so you feel cold and shiver, to try and raise your temperature. The higher body temperature may help fight infection by speeding white blood cell production and slowing bacteria reproduction.
