confused avatar image
confused asked
Where is the safest place to stand outside in a thunderstorm?
scienceweatherstorm
10 |600
einstein avatar image
einstein answered
Tall, pointy objects standing alone in an open space are more likely to get struck by lightning but it’s by no means a certainty. Sometimes the flat ground next to a tall tree can be hit. A car or other enclosed metal structure is the safest place to be in a thunderstorm. Failing that, a ditch, trench or group of shrubs of uniform height is better than nothing. Keep away from boundary areas between dissimilar terrain (water and land; rock and earth; trees and fields). Also keep at least five metres away from metal objects or other people as lightning will often jump from one object to another.
10 |600
