In the first two blogs in this series, we tackled the issue of how REST is a solution to a connected enterprise followed by discussions on What is REST. Then we discussed why use REST for database access. The last blog in this series addressed the following two key issues:
- How to build the REST infrastructure for database access
- What are the requirements you should expect from your vendors of REST infrastructure
In this blog, we summarize the criteria for selecting your REST services platform ? the criteria that was developed in the last blog. We also present how Espresso Logic meets this criteria and this document should serve as a template for you as you embark on vendor selection for REST services platform for your backend for mobile and web applications.
Requirements for REST Platform | Espresso Logic | Other Vendors |
Implementation Services | ||
REST service & database in the cloud | Can connect to your database or provide a cloud database | |
REST service in the cloud, database on the premise | Recommend a reverse SSH tunnel | |
REST service and database on the premise | Offered as a VM Ware appliance | |
Database Services mapped to REST | ||
Tables | Yes | |
Views | Yes | |
Stored Procedures | Yes | |
Databases Supported | MySQL, SQL Server, Azure, Oracle | |
Support for all REST functions | ||
GET | Yes | |
POST/PUT/DELETE for all operations | Yes | |
Built-in Enterprise Class Features | ||
Automatic pagination | Yes | |
Filtering and ordering | Yes | |
Optimistic locking | Yes | |
Custom REST endpoints | ||
Aliasing column names | Yes | |
Automated SQL handling | Yes | |
Projection ? selecting fields to display | Yes | |
Build resource endpoints from external services | Yes | |
Security and Access Control | ||
Default table level security | Yes | |
Role based security derived from your Authentication | Yes | |
Assign privileges by REST endpoints | Yes | |
Row and column level access | Yes | |
API Logic | ||
JavaScript object model | Yes | |
Reactive Rules | Yes | |
Built-in testing and debugging | ||
Interactive REST Lab | Yes | |
Ability to log logic execution | Yes | |
Interactive debugger | Yes | |
Other Service Integration | ||
Able to call any web service | Yes |
